wesnewell
Motor wattage has absolutely nothing to do with choosing a battery pack. So anytime you see an ad that says good for up xxxxW motor, it's just BS. The only thing that matters is device that connects directly to the battery. For any brushless motor that will be the motor controller. Period.
In a brushless motor kit, the rated motor voltage means nothing. A 36V rated motor will happily run on 12V-100V. You need to match the battery pack to the controller you have. To determine what pack to choose, you need to know the controllers max amp draw, max voltage supported, LVC, and HVC if it has one. As an example, I'm going to use a typical controller that comes in a 48V 1000W kit.Max amp draw will usually be 25-30A. Max voltage supported will usually be 63V. LVC will typically be 42V, and if it has a HVC, it will likely be 60V. Assumig a 30A max controller, the pack you choose should be able to provide a minimum of a 30A continuous output, but the more the better as it will strain the battery less. And that's all you really need to know. Be advised that almost all batteries amp rating is likely over stated a lot, so choosing a battery with at least double the max rating is a good idea if you want it to last a long time.
So how does one figure how many amps a battery pack is rated for. Multiply the max discharge C rate times the ah rating of the pack. As an example,a 10ah 20C pack would be rated for 200A.
Questions?
Questions?
