rexey64 said:
let's say you want a higher top speed but you don't know if you can just get it with more current, or if you need a higher voltage.
if you don't have the motor specs like KV, can you measure them and find out what you need ?
Since this is a common question, I'm going to use pictures to explain how I look at it.
It depends on what your top speed is now, how your bike is setup, and your riding position. Fortunately there are a couple of tools that help explain the relationships and estimate the impacts.
For this example, I'm using this as the base case. My assumptions are flat ground, and the motor and battery stay fixed in all examples. I'm also only showing load and power in the graph since that's what I'm focusing on. Note that where load and power lines intersect is the top speed, and in the base case, that point is NOT the peak power that the controller can provide:
The load, on flat ground, it comprised of wind and rolling resistance. In these examples, I'm keep rolling resistance fixed, so the graph below simulates slightly lower than the no load speed of the system, and slightly higher load (to display the actual no load speed, the rolling resistance should be reduced for wheel off the ground, since that would lower the necessary power more to around 40 watts, instead of the 120-ish watts shown in the graph):
If the wind resistance were higher than the base case, you can see that the load graph increases and at some point is equal to the peak power the system can provide:
It's really the wind resistance in these cases that is important.
Now, getting back to the base case and the impact of changing the controller/current limits. In the base case, increasing the controller current limit will make no difference in top speed, since the controller can provide a lot more power than is necessary to attain the existing top speed. The motor winding and voltage are the limiting factors.
In this example, where current is limited to about half of the base case (40A), you can see that power is the limiting factor to move further up on the load curve, and there is a opportunity to increase speed by increasing power:
There is a point where the power, load, and top speed max out, and beyond that point, more power won't increase the top speed. Note that in this example, the top speed of 50A controller is the same as the 70A controller (42.3mph):
Bottom line is that wind resistance is the biggest factor of whether adding more power would increase speed, which is why with the same power, a recumbent can go twice as fast as an upright riding position. Tire pressure and type (eg. fat vs high pressure road) also contribute, but not exponentially.
These two tools are great for getting a feel for these relationships:
http://kreuzotter.de/english/espeed.htm
https://ebikes.ca/tools/simulator.html
You can model your existing setup by using your existing controller current, battery voltage, and modifying the motor Kv in the custom settings to result in your existing top speed, and see where you are along the power curve, relative to the power curves to see it there is an opportunity to increase speed by increasing the current limit.
