dnmun
1 PW
if the solar panels are wired directly to the battery then the solar panel voltage will not exceed the voltage on the battery until the battery hits the HVC on the BMS.
when the BMS resets then the high open circuit voltage will immediately drop to the same voltage as the battery.
there is no situation where the solar panels are at a different voltage from the pack except at HVC and when the panels are dark and there is not enuff voltage to charge the battery.
in that case the diode on top of the solar collector keeps the current from flowing out of the battery and into the p-n junction of the solar cell.
for a 58V DC final voltage you should use an 80V diode at least.
