gsl said:The question remains, why can't I get Rtune to work as intended? But if you could help, you would have done so...
I have read here that this topic was discussed on many occasions but I don't seen to be able to find those discussions in the search. Could you maybe point me to relevant threads so I can better understand the mod or find alternatives?
Thanks
Are you sure it's the controller shutting down and not the battery? The BMS also normally has current limiting unless you're using lipos. You can also get voltage sag in the battery at high current, which will also cause the BMS to cut off. You can pput a voltmeter on the wires between the battery and controller to confirm which is cutting off when you do your brake test.schwibsi said:Could you maybe post a picture, where these resistors are on a KU123?
I have an issue with my new controller. I added some solder, but it shuts down, when I open up the throttle to more than a quarter, when I'm on the bike.
When the rear wheel is lifted up, it will spin full-speed. However, when I start applying the brakes, it'll go up to close to 30A, and then make a noise shut down.
I plan to install 3077 fets and ultralow ESR capacitors, so the heat from 50-60A peak should be fine, but I think I need to change the resistor values to allow for the higher current.
I'll use a speedict mercury to adjust the current limits later. So anything up to 70A peak would be fine.
