Hey, I need a hand. I just found a brushed motor that I may be able to use. It's got a controller, but it doesn't work as a system right now.
So, I'm trying to figure out which bit is the problem. I'd like to test just the motor, and then the controller.
I have a 12v power supply, and a DMM.
Can I just hook the DC power supply up to the motor? Last time I thought I could do something like that, it turns out the load was a dead short and I blew the fuse, which was a pain to replace.
I figure that if I just give the motor (90vdc nameplate rating) 12v dc, it should turn unless it's toast. Am I on the right track?
Katou
PS electronics gurus, I'm about to be given an oscilloscope, any suggestions on starting to learn how to use it?
Katou
