mistercrash
I have a 14S battery and I put two 7S balance tabs on it so the 1420i recognizes the battery as being two 7S packs plugged in series and it balance charges the 14 cells with no problems.
visuthdy said:For those that purchased Hyperion with 1420i ttpack lvc board kit. Does any know if I can cut this board in half? I would like to cut it so I can put the batteries in the hammond case. I'm planning to do 12S2P. thanks.
EBJ said:ok, I know somewhere in this mile-long post is my answer...
but I just spent 30 min looking to no avail.
Question:
When wiring up the balance-wires coming from the Hyperion to go to a DB-25 Connector,
I first just wired my balance wires as if I were plugging in my 2 5S batteries to the hyperion balance port plugs. (one battery to ports 1-6 of 16, then the other battery to ports 9-14 of 16)
It worked well, but I realized after I wired it that way, that when I cycle through the "ports", the Hyperion shows a "blank" voltage for ports 6 and 7...
(because I had skipped over those two and jumped into port 8 to continue w/ wiring the other 5S)
So I have a few questions:
1. What is the best way to wire in 10S to the Hyperion ? (as far as port-use)
2. If I wanted the Hyperion to register 1-10 ports for my 10S pack, then how would I wire in the second 5S balance wires to the Hyperion ?
-examples: first 5s balance wiring is pretty clear... wire "ground", 1, 2, 3, 4, 5.... but then the second 5S pack is a little confusing to me since "ground" voltage is actually the same as (port 6 ... or cell "5" voltage)... in which case, do I wire "ground" w/ the second pack to port 6 w/ "cell 5" ? or do I skip it all together and start wiring "6" to port 7 ? Then what do I do with "port 9" when the Hyperion is wanting "ground" of the high-pack to go there ? arg!.
I'm sorry if no one can follow the above. I find it challenging to explain.
Question:
