docnjoj
1 GW
That washer increases the surface area that helps hold the motor on as opposed to just the round axle. You could use a thinner one or dish the wheel with spoke adjustments to recenter it. Do you have v-brakes? If you have a disc a small bit of off center won't matter much. If V-brakes you should try to center the motor wheel.capo said:Ok I have one more question
Is it ok if i dont use inside washer shown in the picture? Because If i use it, than the rim is out of the fork center to the right.
otherDoc
Oh that is the front wheel and does have a disc. I guess you will have to adjust the spokes for centering. It is like dishing the rear wheel only in the front. You could run it a mm or two off center without a problem.
