I'm using the 6 FET Lyen MarkII mini EB312. I'm going to limit battery current to 35 Amps for a max of 1750 Watts. I'm running two Prodeco 51.2V/12 Ah in parallel for 51.2V/24 Ah so a max current draw of 1.45C. I'm going to initially use the stock 3-wire plug and monitor cable temps. But in reality, I will rarely use anything over 25 Amps and if I do, it will be for very short periods. My motor is sensorless so there are only 3 Phase wires exiting the motor, no Hall sensor wires. I have not taken the motors apart so I don't have bearing info.
EDIT: Well, I finally looked for and saw the 6 extra small contacts way in the back of the connector so I have a sensored motor. Wish I would have seen them before. Back to the drawing board.
