hillzofvalp
So this came up quick. I've dreamed of this job for a while.. and I start on monday. I always thought it would be a perfect exploitation of the bicycle (and a great tip getter). I'm sort of nervous because I haven't done delivery before and I haven't been put in a position where the bike has to be perfectly reliable or I'll get tanked. Current plan:
1) Use current setup with 700Wh of A123. (normally 11 miles horsing around at 5.5kW)
2) When dead, use backpack pack of 750Wh Sanyos.
3) Set CA to 25mph max
4) Limit to 1500W or so
5) limit phase amps to 100 or so
6) Switch to smaller wheel eventually (29" for now).
7) Rebuild bike, replace pads, set up rear hydraulic brakes, make chain alignment goood enough to use 63T chainring practically.
8) add rear storage option on to peak 15lb rated rack (how many drinks will I be carrying?)
Hopefully I will get 15 miles out of each pack. Need good cheap winter gear... especially gloves. Was looking at motorcycle gloves.
I hope this works out.. I will have a car and another regular bike as backup.
None of the other 7-15 delivery guys who ride fixies and such are electric. Here comes a guy with a freakin' overkill electric bike.. they've probably already seen me and wondered... Should be interesting.
