recumbent
I bought 60 volt lipo's but found out my Infineon controler can't handle it. I still use my older set of PSI batteries that are 48 volts, but was wondering if i can knock down the 60 volt lipo pack. Or set my Cycle analyst to a lower amp setting.
I also have an older controler rated 48v from a year ago with 100 volt caps in it but not sure if the 12 mosfets can handle the 60 volts either. "Comcycle" sold the controler to me last year, I'll contact them to see if this older controler is safe to use with 60 volt batteries.
Is there an easy fix for my weaker Infineon controler to handle 60 volts?
I know i probly have to eventually purchase a higher voltage controler.
