bachmaninoff
1 W
I ordered this motor several months ago, have been really putting off installing this thing. But no more!
So I've tired/tubed up the Bafang and put a 7 speed freewheel from my other e-bikekit (which was swapped out with a 7 speed DNP Epoch). Its on the trike! No turning back...
Props to Mr. Xie for taking the time to answer my questions on Live Support on bmsbattery.com! And from a purchase several months ago! Awesome!
Apologize if this info seems basic! Will be putting the pertinent stuff in the wiki after I have a successful OPTEST.
FOR NEWBIES: I already had the KU123 wiring diagram, but didn't have the gouge on how to hook up the throttle with the 3 LED battery indicator and red ON/OFF switch. Yes the KU123 wiring diagram shows the throttle control being 3 wire plug with orange, black and green wires, but my throttle cable had orange, white and black. So I just had to make sure it was the right one on the controller! In addition, there were three other wires attached to the throttle cable: yellow, green and brown. On the throttle cable, green and brown may be soldered together already (and should be if they are not). Yellow is attached to + (RED wire from the battery). In addition, the thin red or orange wire coupled with the power input RED and BLACK on the KU123 needs to get + from the battery pack to power on the controller!
Will post results after I solder an anderson powerpole adapter cable for my existing battery (I have two e-bikekit.com kits, an out-of-commission POS mongoose and a pretty cool BikeE).
Once I get this all sorted out and tested, its going on the wiki!!!
And of course, photos are forthcoming...
