yes, I want an easy and fast way to remove the wheelThe photos show that you have a through axle already. What are you trying to accomplish? No-tools removal?
is that enough? I don't think I can apply much torque by hand using wing nutsUse wing nuts instead of cap nuts on the axle you have. You can have a wing nut on just one side or the other.
is it 7mm is diameter?View attachment 352850
maybe this?
10mmis it 7mm is diameter?
It’s 10mm, look at the photos I postedis it 7mm is diameter?
Sorry, didn’t notice the other scale on your calipers.It’s 10mm, look at the photos I posted
something like this?The bearings don't need any compression. Whatever holds the wheel in securely is enough.
You could use a naked 10mm quick release axle instead of the through axle, and fasten it with a regular skewer, but the bearings would be supported by a threaded surface instead of a cylindrical surface. Still probably okay.
maybe this?
What do you think of this?
