dimpirate
So I just wanted to extend some wires by soldering them together, existing 12 gauge for power and phase, and the smaller 23gauge for the hall wires. I ended up opening controller (not planned) and what do you know it doesn't seem to hard to just replace all the wires instead of extending and adding a weak point in system.
So if I'm already inside I'm gonna change my power and my phase wires to 10 gauge, I should still be able to use 30amp Anderson's right?
I'm using this 12 fet Lyen with 18S4P 66V nominal, and hs3540 hub motor.
What other changes would you guys recommend while this things open?
Controller is set to 45 amps I was going to use at 65 amps with 12 gauge wires, how much more amps can I push thru with 10gauge wires?
(not changing wires from motor, there probobally 12 gauge)
Any help much appreciated!!!
