Kepler said:Really, I don't think the Vesc blows the cost out of the park. I found this excellent deal on a Vesc and perfect motor combo for $188 USD
http://www.michobby.com/product/hot...ess-motorvedder-vesc-for-electric-skateboard/
Agreed, and some of the VESC setups are indeed very well made. I'm in for the VESC-X
$149.46 (price drop!)
(They would discount a group buy.)
http://www.enertionboards.com/electric-skateboard-parts/vesc-x-programmable-brushless-motor-controller/
tomjasz said:Agreed, and some of the VESC setups are indeed very well made. I'm in for the VESC-X
ScooterMan101 said:Do you think they ( enertion ) would make for us , a direct plug/plug adapter , to plug in a standard 3 wire e-bike throttle ?
Meaning a plug on the board for plugging in a 3 wire e-bike throttle . or an adapter connector that mates 3 wire e-bike throttle plug or wires , to connector that plugs into one of the plugs I see on the board.
Kepler said:Did a bit of research into the plug. You will need a JST PH connector with a 2mm pitch (spacing between the pins)
Easiest solution is to just buy some 3 wire pigtails. I found this one locally. https://littlebirdelectronics.com.au/products/jst-jumper-3-wire-assembly
It would be nice to have a true plug and play solution with an adapter that takes up the full 7 pins on the vesc and adapts it to a standard ebike throttle connector. Might look at making a few of these up.
tomjasz said:If you follow Keplers link its Sparkfun in AU.
Here's their USA site. https://www.sparkfun.com/products/9915
ScooterMan101 said:Would JST XH Work ?
... https://hobbyking.com/en_us/male-jst-xh-gt-female-polyquest-6s-10cm-5pcs-bag.html
... https://hobbyking.com/en_us/female-jst-xh-gt-male-kokam-2s-10cm-5pcs-bag.html
or
JST SH Work ? ..... https://hobbyking.com/en_us/30mm-jst-sh1-0-servo-extension-5pcs-bag.html
https://hobbyking.com/en_us/jst-sh-servo-plug-set-jr-gold-plated-10pairs-set.html ( JR Style Terminals )
https://hobbyking.com/en_us/jst-sh-servo-plug-set-futaba-gold-plated-10pairs-set.html ( Futaba )
Or these ... https://hobbyking.com/en_us/jst-sh-3pin-male-with-pig-tail.html
Or these ... https://hobbyking.com/en_us/8pin-male-plug-and-crimp-pin.html
Work ?
Does the / Do the VESC's have JR style or Futaba Style , or other ?
Kepler edit: Fixed up syntax so that the quote would dispay
How would you do this John, how would you protect the other pins. I can't picture it.
https://www.digikey.com/products/en?mpart=PHR-7&v=455
https://www.digikey.com/product-det...ica-inc/B7B-PH-K-S(LF)(SN)/455-1709-ND/926616
HK is one of the poorest places to get misc parts IMO. Places like Spakfun, Mouser and others are electronics professional suppliers. Much higher quality and often products that are direct and better fit. All JST connectors are not equal as has been alluded to. Some ship For Class mail and often un $5. I can always find a couple of parts to add to my repair box to make an order worthwhile. But that's just me...ScooterMan101 said:I am sure Other people would like to get the correct pins/connectors through H.K. as well since many people
order Wire/Solder/Etc through H.K.
tomjasz said:HK is one of the poorest places to get misc parts IMO. Places like Spakfun, Mouser and others are electronics professional suppliers. Much higher quality and often products that are direct and better fit. All JST connectors are not equal as has been alluded to. Some ship For Class mail and often un $5. I can always find a couple of parts to add to my repair box to make an order worthwhile. But that's just me...ScooterMan101 said:I am sure Other people would like to get the correct pins/connectors through H.K. as well since many people
PICTURES PLEASE? Sounds great!ryan74 said:Hi everyone,
Just took my first ride after installing Kepler's bracket. So happy with the results. A few little hiccups along the way but nothing too difficult, running 6s lipo and two button throttle setup as described earlier in the thread. Bike measures 10.13kg with battery, will easy get down to about 9.5kg. It's a Cannondale lefty mountain bike and tonight I'm just using furious Fred mountain bike tyres and there was no issue with hookup. Will measure speeds tomorrow but felt about 45kmh on the flat. Thanks for everything Kepler, It's awesome.
Ryan
Kepler said:Sure, no problems. You would need a minimum of 10 though setup 2S5P. That would give you 24V and 20A
He responds to messages pretty quickly....sotaro said:Thank you for reexamining my question. How do I order and when might the bits arrive?
Ryan
