Klauts said:
That ride is incredible!!! I've been trying to find a way to take my pup on adventures with me, she's about the size of yours too if that's your photo
Yes, that's Kirin (unfortunately i lost her almost two years ago, and Yogi (the mostly-black headed one in the other thread) shortly after), so now it's just JellyBean the Perfectly Normal Schmoo (But a Very Strange Dog)....
You suddenly have me wanting to buy a trike
I feel so gosh dang bad going on long scenic adventures without my little girl
I built the SB Cruiser mostly from scratch; designed partly with intent and partly with by guess and by gosh and experiments over the years. It's not too hard to make one suited specifically to you and your purposes if you can weld steel and do some very basic woodwork.
Before I built the wooden cargo area, I used a dog crate strapped into the frame like this:
You can follow the adventure here:
https://endless-sphere.com/forums/viewtopic.php?f=2&t=67833
and the trailer I built to use with it for big stuff
https://endless-sphere.com/forums/viewtopic.php?f=2&t=76539
and this was the cargo bike preceding it
https://endless-sphere.com/forums/viewtopic.php?f=2&t=12500
and the trailer I built to carry a dog with me since they didn't fit on the bike itself
https://endless-sphere.com/forums/viewtopic.php?f=2&t=63781
Wouldn't have thought about making sure they step-down was rated for 14v you are a veritable fountain of knowledge
Sometimes it doesn't turn off and the drain clogs up and there's a flood....
I know a little bit about a lot of things....mostly stuff I have had to fix or deal with personally one way or another.... But only a very few things I know much about in any detail, and even that isn't the same kind of knowledge most people would have about the same subjects (because I don't think like other people do).
13.5-6v is the most common "automotive" DC-DC voltage, but most real automotive stuff can take from 10-15v, since alternators don't always regulate perfectly and batteries don't always stay charged up.
Just make sure what you're using isn't a true 12.0V device. Most of those will also work a couple volts higher, too, but not all. (The original LED strips on SB Cruiser were meant for just 12v, but they work fine (a bit brighter) on up to 16.4v (the fully charged votlage of my lighting pack)
