I opened up my 48V controller and found that there was very little thermal paste between the metal bar the transistors are mounted on and the aluminum case. There were 4 little spots of paste along its entire 6" length. How disappointing. So I wiped off what was there and coated the metal bar and inside the case with a thin layer of silicone thermal paste and tightened down the screws connecting the case to the metal bar. I could see just a tiny bit of paste squeezed out between the mating surfaces inside the case, and that is just what you want to see. Then put on the end cap and was done.
I thought about using thermal tape, because it works so well on video chips in laptops, but there is not enough space for tape, so thermal paste it is.
This is a simple and easy thing to check if you have the common aluminum fin extruded controller. Even if you are not a techie, its hard to screw this mod up!
I have been building PC's and repairing laptops for years. I can not express how important thermal paste is for proper heat transfer from device to heat sink. Just a $2 tube of thermal paste from RadioShack will go a long way toward maximizing heat transfer to the aluminum case. I'm not sure exactly how much improvement this will give, but it was obvious that the factory did was far from what should have been done.
Excuse me if this has been covered before. I'm a noob.
