lazarus2405
So, my first build came and went with nary a pic. So, for round two, I thought I'd do a little better. Should be a fun ride:
A quick recap of the v1 build:
I ordered a 5304 (which actually turned out to be a 5303) in a 26" rim, powered by 6 Milwaukee V28 packs for an 84v 6ah setup. The heart was 4110 controller, rebuilt by Bob Mcree, with a 55a current limit, and the donor bike was a used Schwinn S25. Top speed was 47mph. The bike died when the dropouts failed, allowing the axle to spin, shoring phase wires, and blowing the controller and Hall sensors.
The only pic of the v1 bike:
So, a short to-do list for the new build:
Torque arms! My, how I need them!
Double the battery, from 500wh to 1kwh.
Increased voltage! 112v9ah, up from 84v6ah
Smaller wheel, from a 26" to a 20"
Regenerative braking
Improved plug braking
Opportunity charging
Watertight, lockable battery container
Improved low voltage electronics (12v and 5v for lights and small electronics)
This is perhaps a conservative list. Ambitious, indeed.
So, where to begin?
Well, for the repair:
A new 4110 v2 Clyte controller is on the way, with a huge thanks to rooney2. I know you're lurking; feel free to post!
A Digikey with new Hall effect sensors is on the way, perhaps arriving today or tomorrow. I'm... looking forward... to soldering those tiny things. :x
I replaced the damaged phase wires with 10AWG. They barely fit through the axle, but fit they do.
A huge thanks goes out to PerplexArt, who offered to CNC some very beautiful torque arms very, very reasonably.
Custom for the Schwinn S-series. Secures torque in both directions. Absolutely beautiful.
And absolutely necessary. The drops are intact, but round:
So, the upgrades:
I covered the batteries pretty well explaining them to mlrosier. I'll just paste that here, with some small edits:
The twelve Milwaukee packs arranged in four subpacks, each containing the cells of 3 packs in parallel, forming a 28v9ah unit. The subpacks are then wired in series for a total of 112v 9ah.
The red lights are the SoC indicator. Red lights means good. :wink:
Each subpack uses one 7-cell Milwaukee BMS, with three cells in parallel per "channel". The BMS sees 7 cells, but it is in actuality seeing the average voltage of three cells. The cells will in parallel balance each other, like water seeking its own level.
The diagram is courtesy of maytag. You'd be interested in his emoli build, here: http://endless-sphere.com/forums/viewtopic.php?f=6&t=541
In this arrangement, one charger fully charges each subpack in a bit under three hours. I use four, one per subpack.
With the three pairs of Andersons snapped together, I can disconnect just one mechanical connector when I want them isolated, like for charging. Apparently the Milwaukee chargers dislike charging packs in series.
This is the naked charger. I removed it from the case, cutting the plastic around the base with a soldering iron to leave nothing but the charger. The three wires on the outer edges, positive, negative, and thermal sensor, have spade connectors to plug into the batteries. The three in the center go to the intact status LEDs. In the upper left of the charger are two male spades for AC power.
And this is the bare BMS. Note the flimsy ribbon cables. Be careful, as they tear easily.
I also put Andersons on a power strip, so that I have an easy way to power accessories. The voltage easily drives switching power supplies. In this picture, it's powering my laptop.
So, where to begin?
So, the upgrades:
