Hello i'm Dennis from the netherlands and i have a question about programming a arduino for my ebike 72v 3000watt. First i will explain what i want:
I read a lot in the forum about throttle limiters, intefaces and tamers but i can't find what i really need.
since i don't know how to write a script for the arduino i'm asking my question here.
What are ebike regulations in the netherlands:
- the motor does not exceed 250 watt
- The bike can only have pedal assist to maximum 25 km/h
- throttle can only be used during pedalling or at startup to 6km/h
So this is what i want it doesn't have too be fancy with displays and everything and of course small and cheap Thinking about a arduino pro mini or nano that i have lying around.
I do know how to use the arduino but this programming is too high for me.
hall throttle in (1- 4 volt)
Pas sensor in (5 magnet disc)
speed sensor in (speedo sensor)
throttle out to ebike controller (1 - 4 volt adjustable)
legal mode:
When legal mode is activated by 5v on i/o port the bike can only drive 6km/h on the throttle or maximum 25 km/h with pedalling.
Offroad mode:
throttle is passed thru arduino (or around by switch) and does nothing with the signal, pas sensor is deactivated.
if possible i like to adjust these things:
max speed in legal mode and offroad mode ( hard coded or pot)
throttle response (not so aggressive in legal mode)
possibilty to attach current sensor for current limiting (not necessary)
toggle between legal and offroad by giving signal 5v to one of the i/o ports
Hope somebody can help me with this. I think this would be usefull for many european throttle drivers
Greetings Dennis
legal mode:
Offroad mode:
Greetings Dennis
