Arbol
Hello, I am looking around to build my e-bike.
So far, I have been suggested a BPM CST 500W 36V motor is a good one for me.
Since it is a 36V motor, I am looking at 36V batteries. One possibility would go with lipos, but LiFePO4 have good characteristics, too. One issue is very few LiFePO4 have cases. And in most cases, they are with polymer cells, with 15A of max continuous discharge current. Since the CST is provided with the KU123 as the kit, and I believe the KU123 accepts up to 30A in a continuous fashion (please correct me if I am wrong), it seems to make sense to get either Headways with a good BMS, or ping / cell_man.
But then, very few of these have cases. The only one I have been able to find is the "36V 10AH Headway 38120 LiFePO4 Battery Pack", in two webpages:
http://www.bmsbattery.com/packs/114-36v10ah-lifepo4-battery-38120-ebike-battery-pack-with-carrier.html
http://www.elifebike.com/peng/iview.asp?KeyID=dtpic-2011-1J-AMQH.1E8NH
But the description is very scarce. In particular:
- BMSbattery does not seem to provide the option to improve the BMS to 30A / 60A, unlike the equivalent battery without a case (which has 30A / 60A and even 50A / 100A as options). Also, one of the pictures in elifebike shows the inside of the case, with the blue Headways, but I cannot see the BMS inside. Could I order this product, but with an improved 30A / 60A BMS, sitting inside the case?
- How is safety designed on this package? There seems to be a key lock, and also the rack seems to be perfectly suited to the battery case. But is the key lock only to open the battery case? Or is the key also fixing the case to the rack, such that a burglar could not steal the battery case (and the battery inside it) without "breaking" the key lock?
