Cryptic
LightningRods said:The wiring that I use is R-R, Blk-Blk, B-G, G-B, Y-Y on the halls and B-B, G-G, Y-Y on the phases. The C-A has it's own JST plug.
Thanks LR - that clears it up
And thanks emaayan
LightningRods said:This feedback just in from Zack in Hawaii on his newly arrived big block kit:
"HOLY CRAP that thing is faster than my 300cc gas [bike] off the line…. amazing and the CG feels so perfect…"
He is having issues with the bike's rear gears skipping so that will be the next hurdle here. With this much massive torque it's going to take some special rear gears to handle it. I REALLY want a Rohloff for my Lunacycle mid bike drive!
Yup, he is s good one to ask about pulling power through a derailer.LightningRods said:You're right Matt. I was being sloppy with my language. I meant rear transmission by "gears". I've been told that the Shimano XTR derailleurs are excellent in high power systems. MotoMoto has run an Astro 3220 through one and supposedly it didn't skip.
r3volved said:Then just swap out for some adamantium pins and you're good to go. Maybe mithril.
Make sure it is grade 9 sub-nuclear iridium hard coated unobtain. :wink:LightningRods said:I'm looking for some pins made from Unobtainium. I can't seem to find a source for them.
recumpence said:Make sure it is grade 9 sub-nuclear iridium hard coated unobtain. :wink:LightningRods said:I'm looking for some pins made from Unobtainium. I can't seem to find a source for them.
It's hard to find in stock, though.
Matt
I have been wondering how to strengthen the rear mech spring and came across thisrecumpence said:It is not the cassette that is the problem. It is the detailer not having enough spring tension. That causes high power systems to chain skip under high loads. He will need to figure out how to stiften the derailer spring.
He will wear out sprockets and chains quickly now with this much power.
Matt
My lunacycle kit did not come with a derailleur hanger. I dug up an old axle mount derailleur from the used parts bin at a local bike shop and it mounted up ok. It looks similar to this:LightningRods said:You're right Matt. I was being sloppy with my language. I meant rear transmission by "gears". I've been told that the Shimano XTR derailleurs are excellent in high power systems. MotoMoto has run an Astro 3220 through one and supposedly it didn't skip.
