markw
Hi ES,
There's been a looming question in my head for some time and I really don't know how to research for the answer, so I thought I'd bring it up here.
I'm curious as to what would occur if one were to leave the balance leads connected in parallel (to a tap) 24/7 including during use (discharge) on my ebike. To be more specific, I'm running 20s2p, and it would be much more convenient to leave the balance leads plugged in to a 8x parallel tap permanently, and for bulk charging just plug in that tap to the charger when needed. It would be prudent to cap the end of the parallel tap just in case of pins bending and causing shorts and simply to isolate the pins from each other.
From my limited reading, the idea in theory sounds neat because the cells would equalize eachother's voltages via the charging tap, ie all balance leads for cell 2 across 8 packs would be connected in p, which would help equalize voltage for IR across the packs cells during and after use. I am aware that the balance leads aren't so clear cut, ie for 5s packs there's actually 6 pins, and that pin 1 is cell 1 - and pin 6 is cell 5 + (possibly way off, here, let me know) and that this configuration may impact the outcome I was hoping for.
Can anyone speak for or against this configuration? Any terminology to help fill the gaps or suggested readings would be most welcome. Thank you!
ps. topic icon chosen was the flame... because I'd rather get flamed on ES for being uneducated than flaming my bod, building, or bicycle with a bust battery wiring.
