Bobocop
amberwolf said:If you had SLA before, then while charging they'd be up around almost 60V (assuming 14.5V+ charge voltage). Even at a nominal full charge of 13.6V each, 4 SLAs would be 54.4V.
I must be missing something then, because at 13.5 or as you say 13.6 = 54.4v for sla's charged,
and lipo 13"s charged (4.2v) would be 54.6, that's pretty even.
3x5's fully charged (4.2) would be 65v, discharging down to 3.0 volts 45.v (to be safe) would not work with my controller,
one, because i think it's to high a voltage (blow the controller)
and second since the my controllers cutout point is 41.5v, i would be discharging them down to far (below 3.0v before the controller cuts out.
From the few posts i read about people switching to lipo's with a 48v system are using 2x6S to get 44v, i haven't read (yet) about anyone going with 3x5S, but i'm still reading
I'll read up more on this voltage thing, but either way weather i get 3x5's or a 7's and 6's I still need to know if i can always leave the balance wires connected in parallel, or do i need to disconnect them after charging ?
