markw
For those of you who dont use BMS and are still using lipo chargers on high power frames like vector, flux, nyx, stealth frames... What does your setup look like? I have made myself a harness for mine that uses andersons inside of a CM 8 chasis that i could install somewhere on my vector frame but im not sure if lipo charging is going to be a perminant part of my ebike in the future. Generally speaking, are BMS a prerequisite to using a high powered frame? What do you think? What does your lipo charging / high powred frame setup look like?
https://www.amazon.com/dp/B00IHOC8QA/ref=cm_sw_r_awd_3Ok5vbV6BW9S7
These are the chasis mounts i referenced
