fechter said:I did make a bit more sophisticated limiter circuit designed for Meanwell supplies, but it would work for most supplies if you can find the right spot to make the voltage sensing connection. http://endless-sphere.com/forums/viewtopic.php?f=31&t=21768
The simple transistor version should be good enough for battery charging, again if you can find the right spot to tie in.
The transistor plan with potentiometer is working great, Thanks for sharing !! I am using your set up to drive 4 cny17-4 opto's to control 4 dell PSU's in series its holding amp draw well. but one out of the 4 PSU's stays high while the others are compensating. Still swaping parts etc. all check good, may be bad resistors from radio shack ??
The potentiometer is very sensative if not right, amps drops low to high with sight adjustment. I am thinking more shunt drop.
Right now the driven side of the 4 opto's is in series, is paralell better ?
Hey Thank's again,
Pete
