bobc
I've started working on a small PCB to "legalise" an RC motor build.
It will be a tiny PCB which connects
1) 3 pin connector to hall effect throttle (twist or thumb)
2) 3 pin connector to an RC ESC
3) 2 bolted connections in the battery -ve line - average battery current measurement
4) 2 pin connector to speedo reed switch (magnet on spoke speed sensor)
there are 2 active components on the board - one is a single op amp amplifying a shunt current measurement, the other is an AVR tiny5 microcontroller. both SOT23 package.
Standard option, you plug in all the bits, you have fixed gearing to the motor (geared so it would naturally drive the bike at 18 to 20mph) - the micro backs off the PWM control to the ESC when either
a) speed goes over 25kph or
b) power from battery goes over 300W (i.e. with 6s batteries, average amps go over 12A).
With a suitably oversized motor you'll get plenty of torque because you'll have constant power available down to about 4mph, so hill climbing performance should be fine. (BTW 300W from batteries is regulation 250W at the wheel....).
I'm going to make a minimalist thing, no indicator lights, battery protection is simply the UVlockout in the RC ESC. So it should cost under a quid to make. Supported by its wiring & covered in heatshrink.
I would expect this to be interesting to folk all over the EU & maybe some other zones. Sound interesting?
On the bike you'd have to pedal to start moving but then it should be twist & go.
I can put layout, parts list & source code on here too or maybe get some made up???
