I finally got around to starting my next build. It's a 2004 Specialized Big Hit which will be powered via a two-speed mid mounted hub motor. The plan is to attach everything using a bolt-on strategy--no welding or punching holes into the original roller. Initial setup will be as follows:
- #35 drive train with a direct drive ratio between 1.5:1 and 2:1 (future plans for belt drive - PolyChain)
- 72V to 100V, up to 2kWh battery, possibly HK lipo or Enerdel
- controller unknown, possibly a home build down the road
- will maintain the 2-speed capability with possible future plans to mod it for single speed once I have some actual motor performance data
I have begun with some renderings and mock-up parts cut from wood.
