nieles
hi
i had an idea for mounting hall sensors to the colossus 7 kW motor
i do not like the method of mounting them in the slots of the stator,
so i came up with this idea.
the new mounting flange will be mounted on the stator instead of the normal mounting flange
i need you guys opinion what is the best solution.
1) hallsensors outside, 17.14 degrees spaced
the magnetic field is sensed through the rotor can.
this is the only option with adjustable timing
2) hall sensors inside, 17.14 degrees spaced
the magnetic field is sensed at the side of the magnets, not sure if this will work.
3) hall sensors inside, 120 degrees spaced
same as 2) only different spacing of the halls
what do you think.
I need a "hall tester" to test the inside mounting method
just a little circuit with an LED, but i dont know how to make it.
does anybody know how to make one?
Niels
what do you think.
Niels
