I am mounting the cheap PAS sensor to the SRAM crank. The sensor mounts fine but the crank arm with gear cluster mounts too close, so I can't mount the disc,so I am planning on moving it to the other side. I will have to make the hole bigger on the magnetic disc. Hopefully it will hold with friction or I will build a clamp using a small hose clamp. I was surprised I could not find much using the search engine. Must be searching using the wrong key words. I know it's a piece of junk but I want to try it with my 3 speed switch and see how it goes.
If someone knows the magnet spacing from the (I think its a hall ) sensor and other details that would be great.
Thanks
Steve
Thanks
Steve
