recumbent
Charger model is 4808sr 3.5 amps out put.
Charger was working fine for three days then just stopped in the middle of a charge, no smoke, but completely dead.
Checked power cord, looked inside, all is fine.
On the side panel it says to use "input fuse 4A/250V output fuse: 10A/250V".
The input fuse is burnt, and is stamped, 15ah/250V, or T5Ah/250V. Changed it with spare fuse supplied and it burnt instantly. However I checked the voltage from my power outlet in my condo and it reads 124volts, not 115 volts as charger says it should be.
What do i do now? get a slightly bigger fuse? the charger does'nt get hot or anything.
I opened it few days ago to "up" the charge voltage from 57V to 59.8 Volts to match my BMS, so the warranty is probly gone.
edit: to make it clearer to understand
