I can't think of a brushed controller (cheap, anyway) that will go that high a voltage, at the moment. There are a few EV-sized controllers, but they're not cheap and they're also pretty large, being intended for much higher currents.
Do you think the controller you already have is repairable?
If you do a bit of modifying it, you could use the 2QD from http://4QD.co.uk
I used one on CrazyBike2 to run the powerchair motor on it, at up to 48V, and managed up to 135A IIRC before I blew the FETs (chain derail and lockup too fast for the overcurrent protection). (also, I built mine from just a bare PCB using salvaged parts).
I originally intended to figure out exactly what to change out on it to make it 100V capable to run a treadmill motor on there at it's full speed/power, but I never got that far before having to try hubmotors (due to frame flex from torque). Theoretically should not be difficult, because of the design, but I'm not that good at figuring such stuff out except by guess and by gosh. :lol:
It comes in several flavors, nto sure which ones they have avaialble right now.
http://www.4qd.co.uk/prod/2qd.html
They also have a couple of others that might be suitable:
http://www.4qd.co.uk/faq/bmnc2.html#cycles
The 4QD can go to at least 68V that I know of.
http://www.4qd.co.uk/prod/index.html
