Lurkin
Some time ago, I made the exact same decision. I pinched pennies. I went hard tail.
I regret it. I consider buying half measures like suspension seat posts is throwing good money away after bad. Some might be satisfied with it, but it's not really comparable to a full suspension bike.
I also went 29er. I would not do so again. Just because it is convenient or cost effective does not necessarily make it a good call in the long run. I found I'm not as confident through tight spots. Would revert to 26er or 27.5", 26er being the preference.
I would not buy a steel framed bike because of its weight. However, it has other advantages - if it cracks in the middle of no where, you have a higher chance of getting it welded well enough to get home.
The most relevant research you can do has nothing to do with what is written on this forum. Go out and try as many bikes as you can - go to bike shops, borrow mates bikes, read posts to see what other people like and why. Maybe the weight of a steel bike is acceptable to you, but not to me. Maybe you prefer hydraulic disc brakes (as I do) to mechanical discs or rim brakes or maybe you weigh less are are not concerned about the rims going out of true and constantly rubbing (as they did for me)
It's tempting in the beginning to just ask on here because it gets a quick, justified answer. But really you should be more concerned with making up your mind based on real experience. I would definitely be taking a decent full suspension bikes out for a ride from the bike shop before going down the path you are currently headed. Further, testing a bike with the suspension/seatpost suspension you are proposing would also be a good idea. You can compare them and make a decision between them, regardless of price or other people's opinions.
It might be worth considering whether you need to save more money over time?
These days I'm more concerned about figuring out what attributes are important to me, then trying to find a bike that meets them, then trying to make it cheap. I think you will end up spending far more in the long run because you have made the decision in the reverse order, with less reliance on real experience (which is exactly what I did).
