kampua
Anyone else has the same problem as experienced by Kepler and Melbourne? wondering how common is that problem.
My Gearing:ebike11 said:What are some of the higher speeds you guys reaching with this motor?
teslanv said:My Gearing:ebike11 said:What are some of the higher speeds you guys reaching with this motor?
48T Chain Ring (Kit Standard)
11T High Gear at Rear
12S HK LiPo Battery, 50.4V HOC.
My top Speed is software limited to 31 MPH - and it seems that I can just barely get it to that speed. (90 RPM at Crank)
However ebike11's question brings up another question:
What is the fastest Crank RPM you are seeing at lower gears & speeds (And is Max Crank RPM a function of Voltage)?
If we can establish the maximum Crank RPM's, then we should be able to extrapolate the maximum possible speed of a given gear ratio.
I will try to do some testing on mine in the next few days.
Kepler said:I will grab a copy if that if you dont mind.
With the fuel economy calc, it is a good idea to add a second calc that takes into account your battery costs and estimated cycles. As with the electrons used, the battery is in reality a consumable also. When you factor this in, economy against an ICE doesn't look quite so exciting. Still other major advantages to take into consideration with electric of course
EVTodd said:Kepler said:I will grab a copy if that if you dont mind.
So true, and if you did the same calculations against a 80 mpg scooter it would be even less exciting. On the other hand, you have to figure in how much insurance, tags, etc, cost for the ice vehicle too.
teslanv said:Kepler,
Per your request - added the battery into the equation.
I wasn't sure about cycle lifespan of my Turnigy Hardcase packs, but it's user definable so you can adjust per real world results. - And really easy to plug in your own battery cost/voltage/capacity/lifespan. Not a bad way to compare battery types, as well, I suppose.
[edit] Added a sheet for the metric world - cause I know how you all hate converting for us Yankees.
Geebee said:Link to Australian retailer BBS01 $500 250w $550 350w http://www.value-e-bikes.com.au/ConversionKits.htm
The sites a mess atm but I have come across it for years when googling and he has distributors in some other states, not Tas
Havent seen a reply to the email sent on the weekend but a phone call might get a quicker response.
And on a totally different note I found this on a French forum
http://cyclurba.fr/forum/278462/bbs01-montage-plateau-bafang.html?from=31&discussionID=13280&messageID=278462&rubriqueID=102&pageprec=
Kepler said:deepfraught said:I stumbled across product news of this switch that attaches to shift cable outer to detect inner cable movement and cut the throttle based on the shift.
http://www.bike-eu.com/Sales-Trends/Product-trends/2013/8/Revolution-in-Bottom-Bracket-Motors-1314760W/
Based on an intelligent gear sensor mounted on the shifting cable, it cuts off the motor drive when the rider activates gear shifting. It eliminates noisy derailleur shifting caused by chain over straining. This new technical solution was developed in the Czech republic and is called 'Gear sensor'. Even in combination with the front derailleur it allows smooth shifting if the e-bike is equipped with a double/triple chainwheel BB motor. The processors enable individual time setting and adjustment for micro-movement sensitivity of the inner cable, to avoid motor cut off caused by cable vibration.
Nice find. Will be interesting to see if it becomes available. At least for now we have a hack that does the same thing. I think this mod was one of the best things I have done with the middrive. Probably not so important on the 250W versions but a great asset on the 750W drive.
m4s73r said:So the question now is does the rpm of the crank change under different amp load. I know most people are looking at this for mountain biking. Im wanting to use it for road touring on a tadpole trike. With a DuelDrive w/11-36 cassette i can turn that 48 into a 36/48/63. at 100 rpm and a 26" wheel thats a top speed of 45 mph in high and 7 mph in low.
