gman1971
- Joined
- Oct 17, 2015
- Messages
- 976
le15otl,
You might need a new crank chainwheel as well, so while you get a new one, flip the current one backwards so the other face of the teeth engage the new chain. Potentially you might need a new freewheel motor sprocket, depending on how bad the wear is on that. I got about 2800 miles out of a BMX chain using first the GNG then the Cyclone before it was at .75% wear. I usually take both chains off the bike for thorough cleanup and measure stretch after 1000 miles, then I do that after ~500 miles. Usually when the chain is at about .5% stretch the time to replace is near... .75% you should seriously consider replace, and anything above 1% stretch its definitively done. Once it gets that bad the entire drivetrain gets chewed up like "no mañana"... Lubing the chain regularly has helped me keep it alive for longer...
G.
G.
