MikeSSS
Hi, I'm MikeSSS in San Antonio, TX. I'm 190 lb, comfortable speed is about 9 to 15 mph, average energy use is about 15 to 20 Wh/mi, average watts are about 100 to 180, all this is based on charging data. We have some climbing here in SA.
Edit to add, the hub motor is an Aotema, brushless, sensorless, 3 wire, direct drive front hub motor.
My ebike is a Japanese mtb, 3 chainrings, 6 cogs, with an older Aotema brushless direct drive front hub motor, battery is 36V gel cell made of three 12V, 12Ah batteries. One of the three batteries is sagging after only 4 miles or so, it has 10.5V at the end of about 8 miles but voltage rises with resting time, the other two batteries have more like 12.4V at the end of the same ride. Rides of 14 miles have a lot of sag in the weak gel cell battery but not the two good batteries. Power is adequate for all but climbing, the motor is just a couple degrees over ambient after 4 miles at 14 mph, with some climbing. I plan to replace the weak battery with a UB 12120, but also want a lighter battery pack, the current pack is just too heavy to be fun to use.
Miles to date are about 200, perhaps higher. The Aotema front hub motor, and controller have been totally reliable.
I use a lot of Lipos for RC planes, multi rotors, crawlers and boats, but don't have any experience with Li ion batteries, other than cell phones. I'm looking at Hobbyking Lipo, 6s, 16000 mah, 22.2V batteries, two would give 44.4V. http://www.hobbyking.com/hobbyking/store/__66310__Multistar_High_Capacity_6S_16000mAh_Multi_Rotor_Lipo_Pack_EU_Warehouse_.html
Is there a 48V controller that would work with the Aotema front hub motor and 44.4V Lipo batteries? I'd especially like to use a half turn twist grip throttle, the thumb throttle on my Aotema rig is just too different than the throttles on the motorcycles I've had. It would really be good if the new controller would also work well with Li ion batteries in the 48 to 52 volt range.
Well, that's it, replace Aotema 36V controller and thumb throttle with a 48V controller and half turn twist throttle and use a 44.4V Lipo battery and also use 48 to 52V Li ion batteries.
This site is most excellent, it is fun to read and very informative.
Thanks,
Mike in San Antonio.
PS, I really like titusmc's bike: https://endless-sphere.com/forums/viewtopic.php?f=6&t=81195
Thanks,
