I am interested in building an ebike. I am relative early in my research process but I thought I would post my goals and concerns here as I build my knowledge.
My goal is to strike the right balance of price, speed, and stealth (aka hub motor). My commute is 9.8mi round trip. Therefore range is not much of a concern. I live in Florida so high torque is not a necessity. I would like to make full use of the power capability of the motor I buy with an appropriate matching controller. I imagine my battery set up in two stages. The first stage I buy now should give me enough to fully power my motor whilst giving my enough juice for a minimum of 20mi. The second stage would be purchased later to add additional range. I have no strict requirement for speed but 55 kph is my goal.
My research thus far as lead me to the Crystalyte HS3540 is seems like a great power/price ratio. This leads me to my first concern: Sensored vs sensorless. I have read that you should go with censored because of compatibility reasons with controllers. Due to the fact I will likely go with a Crystalyte controller (that I assume would be designed to work with either type of motor) makes that argument rather moot. On the other hand I have herd to stay away from the censored due to it being a common failure point. I do not NEED my bike to start from a standstill. Are there any other benefits of a censored version that make up for the increased risk of failure? Due to my goal in speed I will need a higher voltage controller. I have heard that the censors on these motors are doomed at higher voltages.
I recently came across a website that looks to specialize in what I think I need: http://www.ebikedeal.com/
Crystalyte HS3540 - $300
Crystalyte 18 Mosfets 4110 - $170 (I think this is 72v 50A)
Lifepo4 40152S - $28 x (however many batteries I need)
Feedback on the products I have picked out meeting my needs would be greatly appreciated. Also any revenant articles or discussions would be wonderful. If the setup I listed is indeed on par to meet my goals is there a way I can calculate how many batteries I need?
