ZapPat said:
What setups do people use when dealing with long strings of NiMh cells? How to prevent under and over-charging? I've got a few kWh worth of packs here I really want to use! I welcome any practical suggestions / ideas that people use to solve these problems!
I don't think there is any real limit to how long you can make the string, look at the Prius or Honda. They monitor the voltage and temperature of sub-packs in the long string. A microcontroller does a bunch of math on it to detect the battery state.
Of course I can't even program a Basic Stamp, so that approach is out.
Others have used multiple temperature sensors along the string so the charging current would be dropped as soon as any one gets too hot. This seems like a good approach as long as the charging current is reasonable.
I think you can just charge indefinitely with no controls below around 0.1C.
