skeetab5780
Nova Cruz Voloci Project (My first Voloci)
After seeing a few photos of this bike that caught my attention, I started doing a little digging(a lot). After searching for a few weeks on Craigslist and Ebay, one finally turned up for the right price!($175)
I thought about buying it for nearly 2 days before i clicked the "buy it now" button, since it was over 500 miles from where i live and i had to pick it up. Finally I decided to just do it. Luckily i had a friend going to Atlantic City and he offered to pick it up for me. It worked out really well..but i was ready to drive down myself
The bike seems as it was neglected by being left outside a lot, although it doesn't seem to have been ridden too much.
Anyway I've since put about 20 hours of labor into it, scrubbing rust off the rims, removing old dust and grime, and of course.. tearing the entire thing apart and rebuilding it the way i'd like.
Here are some stock pictures before i tore all the OEM parts off (i kept everything intact just for kicks) but time to mess with it..
I did like the stock look of the Voloci but i wanted to shed all unnecessary parts from the bike for a while to
1. reduce weight/clutter
2. rewire/replace the entire main harness
3. clean all the parts individually
4. convert the lighting to LED
5. a lot of the parts were in need of replacement/repair
Here are a few photo's as i take things apart.
Handlebars are slightly bent, but i moved them forward a bit to compensate. I may end up replacing them and possibly the front fork.
There was about 2 inches of caked dirt/debris under the chain cover!
Altho the underside of the cover on the controller side is super shiny still, there is a nice sealing gasket on that side.
Here are a few shots of the stock controller and wiring.
Controller removed. I must say this is a fairly nice controller. But i have different plans at the moment...more on that later
Here i start to situate the wiring and get ready to test a few controllers with this motor.
After a quick test with a 36v 20a controller i saw that the motor still works fine, so i immediately went on to bigger and better things. What can i say my curiosity got the best of me. After all the motor does have a 48v 1000w rating. Went to a 48v controller...that worked, so i went to 72v for a test.
This was with 20s limited to about 20 amps. Its a no go. Its not geared for it and has zero torque at low speeds and takes too long to get up to speed. The motor would also fall apart at those RPMs for too long it seems. I made sure not to stress/overheat it. got up to a good 40mph tho
