so if my uphill commute gets a vented 9C up to 130C regularly, would it be a good candidate for oil cooling?
i picked up some auto/marine sealant and dextron III, but am just wondering if the oil can handle that heat, or if it's better to stay vented...
most car transmissions run much hotter tho they are cooled by the radiator. i doubt the temp will be a problem but if i understand what you guys are doing(new to ebike) you definateley want to vent because of tempature changes causing fluid expansion. most (all i have ever seen) transmissions/rear diferentials are all vented.
probably not relevant but you might be more worried about foaming which also shouldnt be a problem because there should be enuff anti foaming additives in any atf(eduacated assumption) for this application. as well as your not relying on the oil for lubrication so your only risk is loss of cooling. tho a long trip at high enuff rpms if theres any cake mixer scenario(for lack of a more common term) going on with any oil it can turn all your oil into useless foam. side note id also recomend you seal with rtv made to replace a transmission pan gasket(put on wet and filled with atf) you have to get from the auto manufacturer name brand silicons wont seal as well with atf. been out of the field for a lil over 10 years but dodge rtv was by far the best for atf. (no pan gasket all rtv)
ps luv this thread i hope you guys do well cuz there will probably be a bunch of us plagerizing your design so try and do a good job lives are at stake
