docnjoj
1 GW
So I have 5 controllers that now don't work. 2 SineWave S12S, one So9P, one infineon (old) and one Ebikekit sensorless. One of the S12S was a known good, but it was removed from the bike and the put back on with the same hall/phase sequence that used to work. No Go. So9P was brand new and ran for about 1 block and died. It synched up fine at first, then would not run. Infineon was known good when it was removed from the bike to test the Sine waves, which worked great. Ebikekit sensorless spins the wheel perfectly off the ground at 2 amps. But stops dead after a couple of feet in the ground and loses synch. The new motor tester from Lyen shows the 9C motor working fine for phase, halls and throttle.
I am out of patience and out of motors (for a variety of reasons not connected to the controllers.
What should I do next. Batteries are 16000 Multisport new. Could it be the batteries?
That will be my next test after lunch. Seems unlikely but...............otherDoc
C
C
