mountain biker
- Joined
- Sep 26, 2014
- Messages
- 244
how can you change the chain cog for different gear ratio? what would you recommend for example a mid drive...it allows for only chain cog....the ratio is 20 to 1 i believe its a gng 24 volt double reduction....
i have found no cassetes with a big gear on it...only megashimano with a 34 i believe. the standard chain it comes with is a 48 t i believe....
i want a mega low gear for first for sure...and is it possible to still use the derailler?
what different gear options are possible and speeds....lets say 150 is stamped on crank from mid drive or if that is even necessary....to know..just
for academic purposes...how can i change up the gears with a wide gear range....i am looking for low gears...i need to get above 3 mph i guesse for stability...
or can i go lower or will the bike fall over? top speed is not a very crucial thing for me...maybe 20 or so..is cool.
i always heared that 24 volt can get past 15 or so...but i don't know...
i always appreciate you guys with your help...i thank you in advance.....
lets say i have 7 gears to play with on the standard cassete......what can i do...????? and where do i go and get these parts?????
