Arbol
I have been searching for information in this forum about PAS, control cruise, speed switches and all that, and there is a wealth of information. Too much. And many statements are apparently contradicting among themselves, or look too old and probably not applying now at 100%.
For this reason I open this thread.
The question is very basic, but here it is:
European regulations require a motor can only work if the biker pedals. That is fine with me.
Usual implementations of that regulation, if I understand correctly, rely on PAS, which does exactly this: it measures if the biker is pedalling, and if he does, the motor may work. I believe there are several implementations (if biker is pedalling, PAS gives full power; but also if biker is pedalling, PAS gives some amount of power, not fully).
Maybe I am wrong, but I believe an accelerator that worked only if the biker is pedalling would also be legal. In fact, an accelerator would be an "analog" of the digital way of different intensity modes in a multi-mode PAS.
There is additionally the issue of cruise control. Is cruise control working as in cars? ie it tries to keep a constant speed unless the driver brakes? What happens when the biker pedals, the cruise control reduces motor intensity to keep a constant speed?
Finally, there is the issue of 25 km/h max speed for the motor. According to European regulations, the motor cannot help above 25 km/h (but if I pedal stronger, no problem).
To sum up:
I would like a multi-mode configuration with the following modes:
- PAS working (ie the PAS only allows the motor to work if I pedal, and additionally, the PAS selects the intensity of the motor support; no throttle), no throttle, 25 km/h speed max
- PAS working but only to control if I am pedalling or not; the intensity of the motor support is selected only by the throttle; 25 km/h speed max
- PAS working but only to control if I am pedalling or not; the intensity of the motor support is selected only by the throttle; no 25 km/h speed max
- PAS not working, throttle working, no 25 km/h speed max limit (maybe this mode is irrelevant, the 2nd and 3rd one are possibly more important to me)
And additionally, there should be some kind of cruise control.
Is this possible using PAS, switches, throttle ..? I know there is a product called Cycle Analyst which also performs many / all of these characteristics, and is greatly appreciated by the community. I also would be interested in that. I dimly remember having read the CA allows several modes.
Any ideas? Thanks.
To sum up:
Any ideas? Thanks.
