recumpence
1 GW
Hey Guys,
I wanted to let you know David from Phasor Cycles [www.phasorcycles.com] and I are collaborating on a project together. He is designing a new frame around my drive. I will supply the drive and he will supply the frame for a light weight, super high performance chassis kit. He and I will each have one for initial testing. I am sending him a drive for design purposes and he will send me the first production frame using my drive. He will be designing the frame with a spring loaded chain tensioner to eliminate the chain growth concerns.
This will take a little time considering the fact that I need to supply him with a drive system (4 to 6 weeks), then he will design the frame around the drive. So, I bet we are looking at 3 months or so. But, this should be a phenomenal setup once it is all finished.
Our products really seem to compliment each other well. We appeal to the same type of clientele and we are committed to the same end result (extremely high performance, compact, light weight goodness).
I will be sending him a 5 turn 3220 drive (14,000 watt peak, 6,000 watt continuous) fan cooled system to start with...... Eventually he will be running a twin 3220 system. Should be NUTS!
I will keep you all posted!
Matt
Matt
