sketchism
Results from a quick capacity test of possibly the worst batteries i've ever tried, tested 3 of 6 batteries that cost about 800Aud with shipping, which took 3 months to arrive (and one of the packages was lost in transit, i actually paid for 8 )
Not one even reached 80% of advertised capacity, and all went dangerously out of balance under even small load. (Min test load .5A - Max test load 5A .5C )
(tested two batteries on RC charger discharge, and one with a 5A draw from two lightbulbs with meter in line & cell medic attached)
Battery Test
6S 30C 10,000Mah Lipo
BATT 1 - (0.5A slow discharge)
Start V = 25.2 Balanced (4.2,4.2,4.2,4.2,4.2,4.2) Advertised Mah = 10,000
TEST END V = 19.5 (3.7, 3.0, 3.10,3.15,3.18,3.43) (Test ended at 3.0V cell 2)
REAL Mah = 6509
Cell unbalance = 0.43V
Max Temp 33C
BATT 2 - (0.5A slow discharge)
TEST END Voltage = 18.0 (2.8, 3.0, 3.16,3.15,2.9,3) (let cells drop under 3V to get to 18V)
REAL Mah = 6950
Max Temp 33C
BATT 3 (5A nom, 1/2 C discharge)
TEST END Voltage = 19.4V (2.98,3.37,3.48,3.33,3.01,3.28) (test ended at 2.98V cell 1)
REAL Mah = 7600
Cell unbalance = 0.5V
Max Temp 37C
Battery Test
REAL Mah = 6509
Max Temp 33C
REAL Mah = 6950
Max Temp 33C
REAL Mah = 7600
Max Temp 37C
