omegagamer89
1 W
I ordered all my parts and such off of ebay in a first attempt to convert my bike into an electric bike. I am using the following parts:
http://www.ebay.com/itm/110913700071?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
http://www.ebay.com/itm/330737389362?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=251147109564
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=380471563374
I am having trouble hooking it all up. (I want to test it out before I attach any of it to the bike)
Here is what happens:
1) I hook the throttle up to the throttle connector on the controller (Blue to blue, red to red, black to black. I have also tried black to red and red to black)
2) I plug the motor into the motor connector. (This has a specific plug that can only go in one way so I know for sure that part is in right)
3) I connect my 2 12v batteries together in series, then connect one wire from the battery to the power connector on the motor controller, but leave the second one disconnected. Then, when I go to connect the last wire and complete the circuit, it sparks a lot (WAY more than it reasonably should) and if I leave it connected the wires overheat and start to smoke and it even melted part of the housing around the power connector.
HOWEVER. If I just remove the controller completely, and just connect the battery straight to the motor, it works fine.
No sparks, no heating up, no smoke. I even tested it with the polarities reversed, and with one battery or both, to be sure, and it works fine both ways.
So what I need to know is, what am I doing wrong with the motor controller that is causing the wires to heat and smoke like that?
They dont heat up when its just the motor and battery, (no matter how long I leave it connected) so its not that they are too small a gauge to handle the voltage. From everything I can tell, this SHOULD all be working fine. But, for some reason, that darn motor controller just screws up the whole thing when I try to connect it.
Also, FYI, I just leave the brake, brake light, switch lock, charger and indicator connectors unplugged. Could that be a problem or no?
Any help would be greatly appreciated. If anyone could maybe even supply a link to a set of good instructions for what Im trying to do, that would be excellent.
