Programmers have pushed Cell_man over the edge and he will no longer sell controllers to anyone who hadn't purchased a kit. It seems there are those who order controllers, fool with programing without proper understanding or guidance, fry their controllers and cry warranty. What a shame.
"NOTE: We are no longer offering Bafang BBS02 Controllers to anybody who wishes to order 1. We have them available, but will be listed as out of stock if they are ordered through the website. If you are an existing EM3ev customer, we can supply these controllers, just add a comment at checkout that you want to add a BBS02 Controller and the controller type to your order.
Please note that the controller in the BBS02 kit, is the only thing that can fail in a BBS02 kit. If you connect a good controller to a motor that has previously been overheated or has some sort of issue, it will cause the controller to malfunction and likely fail. DO NOT ASSUME THAT THE ONLY PROBLEM WITH YOUR NON-FUNCTIONAL BBS02 KIT IS THE CONTROLLER. If after connecting the new controller, it does not work as you would expect, stop and do some further checks. Please do not assume that we supplied a faulty controller because after you connected it, it made some funny noises, then stopped working after a short time. It is suggested that you at least do a visual inspection of the motor structure (opposite side of housing to the controller), looking for signs of overheating. A replacement controller will not fix burnt out motor windings!
NOTE: Also please note that the BBS02 controllers are easily damaged if programmed incorrectly. If you want to change the program settings, please do not expect them to be covered under warranty.
This a replacement controller intended for the 48V 750W Bafang BBS02, it can be used with either the 500W or 750W version. As can be seen in the images, the controller includes a section of the motor housing and all connnections. It may be necessary to change the battery supply connections, it does not come with the molded waterproof supply connection. The connections, housing etc do add quite a bit of cost, so it is relatively expensive.The sealed PCB makes them rather difficult to do a DIY repair, so it is much more practicle to simply swap the controller section.
The standard settings are as follows:
25A rated. Can be programmed to lower values as listed in options.
LVC (low voltage cut) 41V, suitable for 48V battery. Not suitable for 36V.
Will be configured so the throttle gives 100% assist no matter which assist level is selected.
Number of assist levels are adjustable by the display.
Wheel size can be adjusted from the display.
Speed limit can be set via the display."
