Scootourist
- Joined
- Aug 24, 2015
- Messages
- 10
Hello,
I'm new to the forum, and e bikes. I picked up this kit from BMSBattery:
https://bmsbattery.com/ebike-kit/61...ole+Kit+-+Display+:+LCD1,+RPM+:+201&results=1
In nutshell it's the S06P controller, a 36v10ah LiOn bottle battery and a Q100C CST.
I got it all together this weekend, and it works just fine with no load. When I'm on the bike it won't accelerate. If I pedal to get it going, then use the throttle, the motor will start to move me along, and then a few seconds later it will make a noise and then the motor will cut out. It's kind of a rubbing sound. It sounds a little like that noise you get from old hard caliper brakes when you are braking. Then there is a spinning sound. Here's what I've done so far to try to get past this issue:
-Fully charged the battery and checked to see if it have the correct voltage reading
-un-hooked the brake shut off cable
-tested the throttle - the voltage was OK, the signal was a little low? .9v closed to 3.5v wide open
None of these made difference. Any suggestions on what to check next?
