MrDude_1
Can someone give me a quick sanity check to make sure this all makes sense?
This is the wiring plan for my lipo upgrade. Two 4s lipo bricks make up one 8s unit. I have 4 such units making a 8s4p pack. The stock controller has a 33v limitation, so I am keeping it at this voltage for now.
As you can see the balance leads should go to a DB37 connector, explained below.
The DB37 connector just leads all the balance leads to outside the battery compartment, without interconnecting anything. By not having them all in parallel, if one cell goes bad, it wont try to balance via the tiny balance wires, nor will it drag down all the other cells in parallel... or atleast thats the idea.
The only worry with a D-sub connector is the possibility of bending pins if you're not careful. that is why the batteries are on the female side. so if i wedge a pin in sideways, it will be on the male side... overall just have to be careful and never force the connector.
This is the male side. as you can see I plan to make at least 2 of them.
Plug 1 lets me use a cell-log on each battery and check or balance them individually.
Plug 2 lets me plug in all of them in parallel for balance charging the entire pack.
Anyone have any thoughts? sanity check? props for my mad MSpaint skillz? :lol:
