Hi all,
It seems we are having an issue with my son's well loved Razor MX350, the older model with suspension and 350W motor. When I say "well loved" I mean it has seen a LOT of use over the last two years, a non-zero amount of time was my son riding two-up on it with a buddy... Lately I have noticed it was giving less and less torque, and on our last ride it was constantly getting stuck in the smallest of holes/tall grass/etc. My son is 7 and weighs 74 lbs. I am pretty vigilant about getting the SLAs on the charger after each run and not overcharging them, and these batteries are only about a year old, but my first guess was that the batteries were going.
So yesterday I swapped out the batteries for a known good set from our Razor Dune Buggy, but the same issue. When we got the bike used 2 years ago it would easily loft the front wheel when standing over it and holding onto the bars, and if you blocked the front wheel, the rear wheel would spin. Now it will barely lift the front wheel and the rear wheel will not spin out.
I checked the connections for melting, corrosion, and fit. They were all clean and tight. So assuming it is either the controller not letting enough amps through, or the brushed motor is dying. The rear wheel spins freely, so no bearing issues or brake dragging.
Any easy way to narrow down which it might be, or should I just throw a dart and order the cheaper of the two (the controller) and replace it?
Thanks!
Thanks!
