hi..
i was wondering if you found any particular hot glue which is more suitable then others to attaching cells
the same goes for any padding material like foams to withstand heat.
for example i was wondering if there is any "spary" i can use that would turn to foam and harden around the pack, so for example i would place the pack in a heat shrink spray inside the heat shrink ,and after foam hardens , close and heat the shrink so the battery would all nice and snugly and won't move anywhere.
