I am now working on some of the fine tuning, and am thinking it might be a good idea to replace the tires and inner tubes with something puncture resistant. The 20 inch 2.125 tires I have look reasonably substantial and I have never had a flat tire from a puncture yet, but when this happens to the rear wheel with the hub motor someday, I will probably need to get help if I have to remove the tire. I have managed to find someone 3 miles down the road that fixes ebikes, so instead of someday getting stranded in the middle of nowhere with a flat tire, it may make better sense to plan to upgrade the tires and hire this guy to put them on at a convenient time when I can watch and learn how the back tire is removed and re-installed.
The information below has been helpful
http://www.endless-sphere.com/forums/viewtopic.php?f=1&t=58002&hilit=rear+hub+motor+tire+repair
I have been reading here and it sounds like a 2.25 16 inch moped tire would be a good fit for my bike.
http://endless-sphere.com/forums/viewtopic.php?f=3&t=40123#p618508
I have found some made by Shinko that have the right dimensions. But as my bike has fenders which would get in the way of a tire that is any larger than the ones already on the bike, I am wondering if these tires have the same outer dimensions as the tires I have?
I would also get inner tubes and the ones I am looking at on Ebay are made for 16 x 2 to 2.25, or 2,25 to 2.50. Is the smaller tube the one I should be getting?
And as cheaper solution, would it make my tires more reliable to keep the tires I have and just replace the inner tubes? Or if I go the less expensive route, of just replacing the tubes, can I use the 16 x 2.25 inch moped tubes in the tires I have, or is there a good puncture resistant 2.125 x 20 inch bicycle inner tube which would be better? The inner tubes I have have awkward Dunlop/Woods valves, and when I started reviving the bike the rubber sleeves had completely rotted away ... I replaced these and everything is OK now, but the tires days may be limited... I would like to have replacement parts handy for when it needs them!
